Einleitung
Wireless module in your way? Move it out!
Was du brauchst
Locate the battery and the battery tabs on the bottom of the Compaq Mini.
Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
Unscrew all the corner screws. There are four total, one under each rubber pad.
Remove the three screws in the silver tabs at the back of the keyboard.
Lift the keyboard away from the laptop.
Pry up the top plastic cover using a spudger.
These two tabs under the screen need to be pushed in with a spudger.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
