Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Place the all in one computer face down on a soft, clean surface to avoid scratching the front. Press the tab on the stand cover and lift up. Press the tab on the stand cover and lift up.
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Remove the four phillips screws that attach the stand to the computer. Tilt the stand up and out. Tilt the stand up and out.
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Starting from the optical drive, pry the back cover up with a plastic spudger. The cover is held in place by fragile plastic clips.  Careful to not break them. The cover is held in place by fragile plastic clips.  Careful to not break them.
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
Abschluss
21 weitere Nutzer haben diese Anleitung absolviert.
Tyler
4.431 Reputation
16 Anleitungen geschrieben
TechForce Mitglied von TechForce
Business
2 Mitglieder
18 Anleitungen geschrieben
I took the back cover off because everytime i connected the power cable the blue light on the power cable would go out and in taking off the back cover i might find something obvious. I did not find anything obvious except for a plastic clip floating around by itself. this may be the cause to a short i am thinking. Any ideas?
kim - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 11
Letzte 7 Tage: 37
Letzte 30 Tage: 202
Insgesamt: 23,777
