Einleitung
Prerequisite Only
Was du brauchst
With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
Pull the base stand straight up from the device.
Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
