Einleitung
This guide explains how to remove/replace any part on a Dell Vostro V13 laptop by describing a complete tear-down. Any screwdriver of size PH00 to PH1 will work with the screws on this laptop.
Was du brauchst
Remove the two plastic dummy cards from the laptop.
Unscrew the six PH00 screws from the bottom of the laptop.
Unscrew the two PH00 screws from the back of the laptop, located at the extreme left and right of the back panel.
Slide the bottom cover forward and lift it upwards to remove.
Carefully remove the battery connector. It is a ribbon cable that is clamped down. Flick the black clamp up using the edge nearest the battery. The ribbon cable is now free to move for the next step.
Unscrew the four PH00 screws from the battery.
Lift the battery upwards to remove it.
Unscrew the four PH00 screws from the hard drive enclosure.
To remove the hard drive, gently lift the drive to a shallow upward angle and carefully slide it to the right.
Using a plastic opening tool, pry open the top panel containing the power switch. Start with the bottom-right edge closest to the keyboard.
Unclip and remove the ribbon from the panel.
Remove the two PH00 screws from the keyboard.
Gently lift the keyboard upwards and push it towards the screen to remove.
Remove the ribbon cable from underneath the keyboard.
Remove all of the ribbon cables from the motherboard.
Take out the one screw from the audio card and then lift upward to remove.
Unscrew the six PH00 screws from the memory card reader.
Remove the CMOS battery cable from the motherboard.
Using a small plastic opening tool, gently lift and remove the two antenna cables from the wireless card.
Unscrew the one tiny screw securing the wireless card.
Gently slide the card forward to remove it.
Remove all six screws from the motherboard.
Unscrew the two PH00 screws from the cooling fan.
Gently lift the motherboard upward and then slide it forward to remove.
Push the two metal clips on either side of the RAM outward; the memory chip will pop up.
Pull the memory down from the slot to remove it.
Unscrew the four PH1 screws from the heatsink.
You may also need to remove the screw on the fan shroud.
Pull the heatsink and the fan upward to remove both.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
is the CPU removable?
No, it's not. All laptops have soldered ballpoint CPUs and GPUs.
