Einleitung
This guide will show you how to successfully separate the tablet's rear panel from the touch screen.
Was du brauchst
The rear panel is secured to the front case and can simply be pried apart without damage.
Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
4 weitere Personen haben diese Anleitung absolviert.
