Ersatzteile
Kein Ersatzteil erforderlich.
  1. Make sure the camera is turned off here. Remove batteries from the battery compartment located on the bottom of the camera Remove SD card for the card reader compartment located on the flat side (left side)  of the camera
    • Make sure the camera is turned off here.
    • Remove batteries from the battery compartment located on the bottom of the camera
    • Remove SD card for the card reader compartment located on the flat side (left side) of the camera
  2. Remove 2 screws on the rounded side of the camera wisdom here.
    • Remove 2 screws on the rounded side of the camera wisdom here.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove 3 screws on the flat side of the camera All silver screws go into the side of the camera that is silver
    • Remove 3 screws on the flat side of the camera
      • All silver screws go into the side of the camera that is silver
      • All black screws go into the side of the camera that is black
  5. Remove 4 screws from the bottom of the camera
    • Remove 4 screws from the bottom of the camera
  6. Separate the front and back pieces of the cameras plastic casing using a spudgerm here. WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control Use minimal force so that the plastic casing does not break
    • Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
      • WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
      • Use minimal force so that the plastic casing does not break
      • When separating the small silver sliding indicator for view/off/playback may fall out
      • The plastic viewing window located on the top of the camera may also become lose and fall out
Abschluss
Brittany
101 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-5, Buehl Spring 2013 Mitglied von Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
4 Mitglieder
3 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 46
