Zum Hauptinhalt wechseln
Disassembling Ericsson CF 388 Sim Card
Was du brauchst
  1. Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Battery: Schritt 1, Bild 1 von 3 Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Battery: Schritt 1, Bild 2 von 3 Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Battery: Schritt 1, Bild 3 von 3
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
  2. Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Sim Card: Schritt 2, Bild 1 von 2 Disassembling Ericsson CF 388 Sim Card, Disassembling Ericsson CF 388 Sim Card: Schritt 2, Bild 2 von 2
    • After removing the battery, the SIM card is accessible. Locate the SIM card casing at the bottom right of the back of the front panel casing.
    • To remove the SIM card, using your index finger, carefully lift up and rotate the plastic casing.
    • Then, the SIM card easily slides out of the casing.
Abschluss
Cam Miller
1 Reputation
1 Anleitung geschrieben
Clemson, Team 1-1, Benson Spring 2012 Mitglied von Clemson, Team 1-1, Benson Spring 2012
CLEM-BENSON-S12S1G1
3 Mitglieder
21 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 978
