Was du brauchst
Press and hold down the black button below the handle while pulling the pole out.
Press the black separator switch to separate the top and bottom halves of the vacuum.
Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
Eine weitere Person hat diese Anleitung absolviert.
