Einleitung
This guide will show you how to open your Flip Video and remove the main circuit board.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Turn off the device and take the batteries out. Remove metal sticker under the LCD screen with a spudger.
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
  2. Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  3. Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell. Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  5. Open battery door. This can be done by gently depressing and sliding the battery down downward.
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
  6. Use the spudger to separate outer shells.
    • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
  7. Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
    • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
  8. Slowly lift the left side of the circuit board.
    • Slowly lift the left side of the circuit board.
      • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
  9. Disconnect the USB port cable from the back side of the circuit board.
    • Disconnect the USB port cable from the back side of the circuit board.
  10. Slide out the battery contacts.
    • Slide out the battery contacts.
      • Battery contacts
      • Slot where battery contacts were located
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Elizabeth
100 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 26-21, Regan Spring 2010 Mitglied von Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Mitglieder
Thank you. Where is the reset button on these first generation Flip Videos (mine doesn’t have one visible on outside, must be on inside.
sherrygray - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,041
