Zum Hauptinhalt wechseln
Disassembling Galaxy Tab S 10.5 Back Cover
Was du brauchst
  1. Disassembling Galaxy Tab S 10.5 Back Cover, Disassembling Galaxy Tab S 10.5 Back Cover: Schritt 1, Bild 1 von 2 Disassembling Galaxy Tab S 10.5 Back Cover, Disassembling Galaxy Tab S 10.5 Back Cover: Schritt 1, Bild 2 von 2
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Disassembling Galaxy Tab S 10.5 Back Cover: Schritt 2, Bild 1 von 1
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Disassembling Galaxy Tab S 10.5 Back Cover: Schritt 3, Bild 1 von 1
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
Abschluss
20 weitere Nutzer:innen haben diese Anleitung absolviert.
Jordan Soto
3.249 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 3-2, Eyestone Fall 2015 Mitglied von USF Tampa, Team 3-2, Eyestone Fall 2015
USFT-EYESTONE-F15S3G2
3 Mitglieder
20 Anleitungen geschrieben
6 Kommentare
This is very misleading and not the correct way to open this device. This will damage the backplate and the antennas that are glued together. The proper way to open this tablet is from the front taking the LCD out of the frame.
jamee - Antwort
I have completed this disassembly multiple times without issue. There is nothing glued to that part of the unit.
G C -
I disassembled and assembled back SM-T805 for motherboard replacement 2 hours ago. Discovered that back cover have a row of tiny pins with tips molded into back cover rim who are designed to break out and larger pins who will click open and back on closing just fine. Also back cover rim is glued to cover with weak glue. Seems someone Samsung decided that those larger pins alone are not enough to keep back cover firmly in place without flapping around. In reality larger pins alone on assembling will click back and keep cover in place just fine.
However I agree to you that correct way is to carefully open this tablet from screen side with these small blue flat openers or with plastic cards. It will be faster as well. Back cover rim should be removed only to replace antennas. I hope that author of these manuals will fix that.
Jānis Baumanis -
Jamee is right, the SM-T805 (3G) can be opened separating the cover from the LCD, and not by removing that back cover that is glued to the rest.
German Palacio - Antwort
How can I get another charging female component
peter toombs - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 27
Letzte 30 Tage: 121
Insgesamt: 38,111
