Einleitung
This guide shows how to fully disassemble a Garmin Nuvi 1200 to replace the logic board.
Was du brauchst
Remove to sticker on the back of the unit and then remove the two T5 scremws once this is done use a spudger to carefully pry off the silver cover.
Once the tool is inserted it can slide around the entire device.
Lift cover off of unit.
Be careful not to lose small rubber piece on the bottom right corner.
Gently lift the logic board out of the unit
Be careful not to damage the battery connector on the top of the unit.
6 weitere Personen haben diese Anleitung absolviert.
