Einleitung
A side panel is located on each side of the device. The right side panel, containing the button(s), controls the track being selected as well as the volume of the device. There are no prerequisites required for this guide.
  • A pry bar is necessary to remove the panel.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Use the plastic opening tool.
    • Use the plastic opening tool.
    • Lodge the tip into the corner of the device; Applying pressure upward, allowing the panel to be released.
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. The side panel can now be detached using your fingers. The buttons can be dislodged by turning the panel over and shaking it, if necessary. The buttons can be dislodged by turning the panel over and shaking it, if necessary.
    • The side panel can now be detached using your fingers.
    • The buttons can be dislodged by turning the panel over and shaking it, if necessary.
Abschluss
After disassembling, the device and its components should look similar to that depicted in the cover image (top right of page).
Alexander
101 Reputation
9 Anleitungen geschrieben
Clemson, Team 15-3, Benson Spring 2012 Mitglied von Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 819
