Einleitung
In order to gain access to most of the internal components the top (or lid) of the printer must be removed. This guide is intended as a prerequisite for other installations.
Was du brauchst
Open the front access panel by placing your finger in the front slot and pulling gently.
Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
Carefully lift the top panel off of the printer.
Do not tear or damage the two cables that connect the top lid to the motherboard.
Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
21 weitere Nutzer:innen haben diese Anleitung absolviert.
