Einleitung
This guide will teach you how to get at the internal components of this device by safely removing the two plastic covers on the back.
The covers are attached with a few screws each and snap-on tabs within the device itself. The internal tabs will give you the most trouble so keep the plastic opening tool nearby at all times. When using the plastic opening tool make sure you have a firm grip on the device or another set of hands to help keep it steady. Of course use your best judgement when it comes to prying at the covers, they are quite durable but will certainly snap if put under too much pressure.
Please note that all the screws for the back cover are the same size and length so while you should try to keep track of your screws, don't fret if some of them get mixed up in the process.
Good luck!
Was du brauchst
Remove the SD card in the bottom of the computer by pressing the SD card in, and it will pop out.
Pull out the SD card completely and set aside.
Remove the two rubber screw covers on the bottom of the plastic cover using the plastic opening tool.
Unscrew the two 6.35 mm PH#1 screws that were underneath the rubber covers.
Use the plastic opening tool along the outer rim of the bottom portion of the back panel.
Take off this portion.
Remove three 6.35 mm screw from the back panel using a PH#2 or J1 screw driver.
Unscrew the two 6.35 mm PH#2 screws. They aren't able to be completely removed and will just be loosened similar to step 3.
Release the stand by pressing the large button on the left so that it is easier to take the back case off.
Use the plastic opening tool to separate the silver back cover from the screen body.
As shown in picture two, use the tool around the stand as well to avoid cracking the cover.
Slowly apply pressure to the outsides of the cover until it pops out of place.
Carefully lift the cover away from the computer and untangle it from the stand.
Disconnect the battery by using a plastic opening tool and taking the cable connection out.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
