Zum Hauptinhalt wechseln
Einleitung
Prerequisite only
Ersatzteile
Keine Ersatzteile angegeben.
  1. Power-off the netbook fully before attempting to remove the battery. Flip your netbook upside down, and locate the sliding tabs near the battery. Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
  2. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Jetzt kaufen
    iPhone X Fix Kits
    Jetzt kaufen
  3. Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover. Next, take a Phillips PH1 screwdriver and unscrew the two screws. These screws will not release from the cover once they are unscrewed.
    • Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover.
    • Next, take a Phillips PH1 screwdriver and unscrew the two screws.
    • These screws will not release from the cover once they are unscrewed.
    • If necessary, use the flat end of the spudger to assist in prying the cover away from the computer.
Abschluss
Jared Cooper
637 Reputation
5 Anleitungen geschrieben
Clemson, Team 14-1, Benson Fall 2013 Mitglied von Clemson, Team 14-1, Benson Fall 2013
CLEM-BENSON-F13S14G1
3 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 42
