Zum Hauptinhalt wechseln
Disassembling HP Pavilion g7-2275dx Back Panel
Was du brauchst
  1. Disassembling HP Pavilion g7-2275dx Back Panel, Battery: Schritt 1, Bild 1 von 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
    Frag FixBot
    Kommentar hinzufügen
  2. Disassembling HP Pavilion g7-2275dx Back Panel: Schritt 2, Bild 1 von 1
    • The battery is held in by a latch in the front and tabs in the back.
    • Slide the lock switch left, towards the center of the computer.
    • Lift up the battery, rotating it up and away from you, then pull it out.
    • To put the battery back in, line it up with the battery bay and the holes for the tabs. Then let the battery rotate towards you and press down until the latch engages and you hear a click.
    Frag FixBot
  3. Disassembling HP Pavilion g7-2275dx Back Panel, Disassembling HP Pavilion g7-2275dx Back Panel: Schritt 3, Bild 1 von 1
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
    Frag FixBot
  4. Disassembling HP Pavilion g7-2275dx Back Panel: Schritt 4, Bild 1 von 2 Disassembling HP Pavilion g7-2275dx Back Panel: Schritt 4, Bild 2 von 2
    • Slide the back panel down and pull it up.
    Frag FixBot
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 11-51, Amido Spring 2014 Mitglied von Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 Mitglieder
21 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 30
Insgesamt: 3,461
