Was du brauchst
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Firmly pull the the back of the side panel until it separates from the body of the printer.
Rotate the side panel upwards while pulling it towards yourself to remove the panel.
Rotate the printer 90 degrees clockwise.
Grasp the paper tray and rotate it down.
Insert your fingers into the slot in the printer door and pull to rotate the gate down.
Remove the two T10 12 mm Torx screws.
Grasp both sides of the side panel and pull it forward to remove the panel.
Rotate the printer 90 degrees counter clockwise.
Lift the scanner lid to expose the scanner glass.
Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
Remove the front panel by grasping its front and pulling away from the printer.
Remove the cable connecting the top panel of the printer to the power button assembly.
Set aside the top panel of the printer.
Remove the two T10 12 mm Torx screws from the top front of the printer
Rotate the Printer 90 degrees counter clockwise.
Remove the scanner cable from the main circuit board.
Using both hands, lift the scanner tray from the body of the printer.
Remove the power button circuit board from the support frame by pinching the left side, and pulling forward and to the left simultaneously.
Push up on the tab holding the secondary control circuit board with the spudger and pull it forward to remove it.
Lift the support frame off of the printer body with both hands.
Remove the printer door and paper tray by putting them in the closed position and not laying flat then rotating them upwards lift the left side up.
Remove both of the ink cartridges by grabbing the front of the ink cartridge and pulling down.
Remove the T10 6 mm Torx screw on the left side of the track assembly.
Remove the T10 12 mm Torx screw on the left side of the track assembly.
Remove the cable connecting the ink cartridge carriage to the main circuit board.
Carefully remove the connector holding the drive motor wires to the main circuit board.
Slide the ink cartridge carriage all the way to the right side of the printer.
Using both hands, carefully lift the ink cartridge track off of the main body of the printer.
12 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Thank You sooo much….Just what I needed
One of the 4 pins on this spring loaded plastic piece on the carriage farthest one to the right popped off and for some reason it raised up and was stopping the carriage from sliding left..So once I got the carriage off it dropped back down ,spring is fine so I snapped the pin back in…cool i thought it was broken…So I’ll clean it up put it back together and see what happens
Sure hope I can get those cables back in rite
I’ll let you know!!! >>—-@—->
Wpw its working
Got rid of the flashing orange light,carriage is sliding left an right ,printed a test page…WOOOHOOO!!!
Thank you all again so much
