Zum Hauptinhalt wechseln
Disassembling HTC One V Back Case
Was du brauchst
  1. Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: Schritt 1, Bild 1 von 3 Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: Schritt 1, Bild 2 von 3 Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: Schritt 1, Bild 3 von 3
    • Power off your device.
    • Remove the bottom cover by sliding it off.
  2. Disassembling HTC One V Back Case: Schritt 2, Bild 1 von 1
    • Remove the SIM card.
    • Remove the four screws securing the bottom casing.
    • Two 3.0 mm Phillips #0 screws in the top left and right corners.
    • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
  3. Disassembling HTC One V Back Case: Schritt 3, Bild 1 von 2 Disassembling HTC One V Back Case: Schritt 3, Bild 2 von 2
    • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
  4. Disassembling HTC One V Back Case: Schritt 4, Bild 1 von 3 Disassembling HTC One V Back Case: Schritt 4, Bild 2 von 3 Disassembling HTC One V Back Case: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to pry open the bottom casing.
    • Remove the bottom casing by pulling it towards you.
  5. Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: Schritt 5, Bild 1 von 3 Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: Schritt 5, Bild 2 von 3 Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: Schritt 5, Bild 3 von 3
    • Use the plastic opening tool to pry open the rear camera panel.
    • Remove both screws that are securing the back case.
    • One 4.0 mm Phillips #0 screw.
    • One 3.0 mm Phillips #0 screw.
  6. Disassembling HTC One V Back Case: Schritt 6, Bild 1 von 3 Disassembling HTC One V Back Case: Schritt 6, Bild 2 von 3 Disassembling HTC One V Back Case: Schritt 6, Bild 3 von 3
    • Use a Jimmy to pry up the OEM SIM and SD card reader contact.
    • Pry from right to left to avoid potential damages to the ribbon.
  7. Disassembling HTC One V Back Case: Schritt 7, Bild 1 von 3 Disassembling HTC One V Back Case: Schritt 7, Bild 2 von 3 Disassembling HTC One V Back Case: Schritt 7, Bild 3 von 3
    • Using both thumbs, gently push on the two bottom rear corners of the motherboard.
    • Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 1-3, Blackwell Winter 2015 Mitglied von USF Tampa, Team 1-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G3
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 3,011
