Einleitung
This introduction shows how to open the main set of a Philips MCD288/??. It should be the same for all /??s. The front panel might get buckled a bit.
Was du brauchst
To lift an edge, shift the front part at that edge towards the side while bending both parts apart (picture of the inside at step 5)
hint: Start at the bottom, then continue with the sides according to step 4, because the bottom is only fastened by the screws of step 1, while the top has 3 extra latches (seen in step 5).
To detach the sides, pull a main latch towards you and keep on lifting the top part further.
repeat for three latches on each side.
These pictures show the latches on each edge and on the top of the set.
3 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Tenho um mini system Toshiba não alimentação elétrica
