Einleitung
To take the floppy disk drive out, remove the battery first.
Slide the highlighted tab to the left.
With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
There is a switch located just above and to the right of the drive.
Slide the switch to the right. A small, black tab will pop out.
Pull the small black tab away from the computer to access the drive.
Gently pull the drive out from the laptop.
If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
To reassemble, place the floppy disk drive back into its bay the way it was facing before
