Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
To take the floppy disk drive out, remove the battery first.
  1. Flip the ThinkPad over so that it is upside down. Slide the highlighted tab to the left.
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  3. Hold the Thinkpad as the picture shows. There is a switch located just above and to the right of the drive.
    • Hold the Thinkpad as the picture shows.
    • There is a switch located just above and to the right of the drive.
    • Slide the switch to the right. A small, black tab will pop out.
  4. Pull the small black tab away from the computer to access the drive. Gently pull the drive out from the laptop.
    • Pull the small black tab away from the computer to access the drive.
    • Gently pull the drive out from the laptop.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
Abschluss
To reassemble, place the floppy disk drive back into its bay the way it was facing before
Jessica
162 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 4-44, Amido Fall 2010 Mitglied von Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Mitglieder
26 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 2,299
