Zum Hauptinhalt wechseln
Einleitung
The lower bracket needs to be removed to get to some components of the laptop.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Disassembling IBM ThinkPad T42 Lower Bracket, Bottom Cover: Schritt 1, Bild 1 von 1
    • Unscrew the 20 Phillips screws on the underside of the T42.
    • For ease of reassembly, keep your screws organized.
  2. Disassembling IBM ThinkPad T42 Lower Bracket, Rear Screws: Schritt 2, Bild 1 von 1
    • Unscrew the 2 Phillips screws on both sides of the T42's rear.
  3. Disassembling IBM ThinkPad T42 Lower Bracket, Keyboard/Trackpad Removal: Schritt 3, Bild 1 von 1
    • Flip the laptop over and open the screen.
    • The bezel and keyboard will be loose, be careful.
  4. Disassembling IBM ThinkPad T42 Lower Bracket, Disconnecting Ribbon Cables: Schritt 4, Bild 1 von 2 Disassembling IBM ThinkPad T42 Lower Bracket, Disconnecting Ribbon Cables: Schritt 4, Bild 2 von 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. Disassembling IBM ThinkPad T42 Lower Bracket, Lower Bracket Removal: Schritt 5, Bild 1 von 2 Disassembling IBM ThinkPad T42 Lower Bracket, Lower Bracket Removal: Schritt 5, Bild 2 von 2
    • The metal bracket will now be free to move, grasp it and remove it from the device.
  6. Disassembling IBM ThinkPad T42 Lower Bracket, Remove the Microphone Cover: Schritt 6, Bild 1 von 1
    • Remove the small rubber piece that is covering the T42's microphone,
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Cal Poly, Team 29-76, Johann Spring 2010 Mitglied von Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Mitglieder
30 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 3,304
