Zum Hauptinhalt wechseln
Disassembling IBM WorkPad c3 Back Case
Was du brauchst
  1. Disassembling IBM WorkPad c3 Back Case, Back Case: Schritt 1, Bild 1 von 2 Disassembling IBM WorkPad c3 Back Case, Back Case: Schritt 1, Bild 2 von 2
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
  2. Disassembling IBM WorkPad c3 Back Case: Schritt 2, Bild 1 von 1
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
  3. Disassembling IBM WorkPad c3 Back Case: Schritt 3, Bild 1 von 2 Disassembling IBM WorkPad c3 Back Case: Schritt 3, Bild 2 von 2
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
Abschluss
Cal Poly, Team 21-35, Regan Fall 2010 Mitglied von Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 1,472
