Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Open the liquid-crystal display (LCD) screen.
Using a Phillips #1 screwdriver, remove the two hinge screws.
Remove the hinge cover. Shut the screen after the cover is removed.
Flip the camera over to look at the bottom panel.
Remove the five screws that are located along the sides of the bottom panel with a Phillips #1 screwdriver.
Push the eject button beneath the bottom panel to open the cassette cover.
Shut the cassette cover.
Place the camera upright.
Open the LCD screen. Move the dark gray tab located near the eyepiece aside.
Remove the screw located under the dark gray tab with a Phillips #1 screwdriver.
Replace the dark gray tab and close the LCD screen.
Go to the side of the camera that is opposite the LCD screen.
Remove the two screws located on this side of the camera with a Phillips #1 screwdriver.
Go to the side of the camera that has the LCD screen.
Place the plastic opening tool into the seam between the top cover and the bottom cover of the camera.
Pry the top cover from the bottom cover until you hear a snapping sound.
Gently remove the top cover from the camera base.
2 weitere Nutzer haben diese Anleitung absolviert.
