Zum Hauptinhalt wechseln
Einleitung
These instructions will demonstrate how to remove the battery from the KDDI Kyocera A5521K.
  1. Turn the phone over to expose the battery cover. Apply pressure to the back of the battery cover to slide it down. The battery cover is now separate from the phone.
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Remove the battery by pushing it up and out from the bottom. The battery, cover, and phone should now be separated. The battery, cover, and phone should now be separated.
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Dominic Grisafe
157 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 28-25, Regan Spring 2010 Mitglied von Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Mitglieder
20 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 2,080
