Was du brauchst
Take a small flat screwdriver or any plastic opening tool and start to remove the silver cover.
The backing has lots of double sided tape to hold this down so some force will be required.
Carefully push from the side you just opened. All the inside parts should slide out from the back of the unit.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
