Zum Hauptinhalt wechseln
Disassembling LG 440G Rear casing
Was du brauchst
  1. Disassembling LG 440G Rear casing, Turn off phone.: Schritt 1, Bild 1 von 1
    • Turn the device off.
    • To do so, press and hold the red button.
  2. Disassembling LG 440G Rear casing, Flip phone.: Schritt 2, Bild 1 von 1
    • Flip the phone over.
  3. Disassembling LG 440G Rear casing, Rear cover removal.: Schritt 3, Bild 1 von 1
    • Slide the rear cover downward
    • Lift it off to access the battery
  4. Disassembling LG 440G Rear casing, Removal of battery.: Schritt 4, Bild 1 von 1
    • Locate the small rounded recess to get access to the battery
    • Gently, lift the battery
  5. Disassembling LG 440G Rear casing, Unscrew six screws along edges of casing: Schritt 5, Bild 1 von 1
    • Use a Phillips #00 screw driver to remove six screws.
    • Save screws for reassembly.
  6. Disassembling LG 440G Rear casing, Lift casing cover: Schritt 6, Bild 1 von 2 Disassembling LG 440G Rear casing, Lift casing cover: Schritt 6, Bild 2 von 2
    • Run the plastic opening tool along the edge of the phone to release the casing cover.
    • Lift the casing cover.
Abschluss
Emily Class
107 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-1, Buehl Winter 2015 Mitglied von Ohio State, Team 1-1, Buehl Winter 2015
OSU-BUEHL-W15S1G1
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
this would be most probably, the same guide to tear down the LG B470
douglas flores - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 1,644
