Zum Hauptinhalt wechseln
Disassembling LG420G Entire Phone
Was du brauchst
  1. Disassembling LG420G Entire Phone, Phone: Schritt 1, Bild 1 von 1
    • Flip the phone over with the screen facing down.
    • Remove the cover and battery.
  2. Disassembling LG420G Entire Phone: Schritt 2, Bild 1 von 2 Disassembling LG420G Entire Phone: Schritt 2, Bild 2 von 2
    • Apply light pressure to the area shown and pull out gently to remove the SIM card.
  3. Disassembling LG420G Entire Phone: Schritt 3, Bild 1 von 3 Disassembling LG420G Entire Phone: Schritt 3, Bild 2 von 3 Disassembling LG420G Entire Phone: Schritt 3, Bild 3 von 3
    • Using a Phillips #000 screwdriver, remove all six screws.
  4. Disassembling LG420G Entire Phone: Schritt 4, Bild 1 von 1
    • With your tweezers, gently pry around the sides to expose the circuitry.
  5. Disassembling LG420G Entire Phone: Schritt 5, Bild 1 von 1
    • Separate the plastic shells gently and place both now exposed pieces on the ground.
  6. Disassembling LG420G Entire Phone: Schritt 6, Bild 1 von 2 Disassembling LG420G Entire Phone: Schritt 6, Bild 2 von 2
    • Remove the small parts gently with your fingers.
  7. Disassembling LG420G Entire Phone: Schritt 7, Bild 1 von 1
    • Remove the circuit board.
  8. Disassembling LG420G Entire Phone: Schritt 8, Bild 1 von 1
    • Gently push the keypad out of the phone frame.
  9. Disassembling LG420G Entire Phone: Schritt 9, Bild 1 von 2 Disassembling LG420G Entire Phone: Schritt 9, Bild 2 von 2
    • With an opening tool, start opening the front face of the phone.
  10. Disassembling LG420G Entire Phone: Schritt 10, Bild 1 von 1
    • Gently remove the front cover to further expose electronics inside.
  11. Disassembling LG420G Entire Phone: Schritt 11, Bild 1 von 1
    • Gently pry apart glued layer.
    • Use an electronic safe adhesive remover to mitigate the risk of damage.
  12. Disassembling LG420G Entire Phone: Schritt 12, Bild 1 von 1
    • The completely disassembled phone should look similar to the picture shown.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 28
Insgesamt: 997
