Einleitung
Most of the screws that you will be removing are threaded into plastic; be careful when reinstalling screws as they can be easily cross threaded or break the plastic.
Was du brauchst
Remove the six gray 25mm hex screws with a 4mm allen wrench.
Carefully lift up the wheel, but do not disconnect it from the rest of the device.
Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
Remove the innermost three 37.5mm silver screws with a Phillips #2 screwdriver.
Remove the wheel hub and push the connector through the center of the hub.
The wheel hub can now be set aside and flip over the steering wheel housing to reveal the under side.
Remove the eight 15.9mm silver surrounding screws underneath the wheel housing with a Phillips #1 screwdriver.
Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
The housing cover can be set aside until you put the wheel back together.
Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #2 screwdriver.
Unplug the three plastic connectors on the left side of the PCB board.
Unplug the two plastic connectors on the top of the PCB board.
Unplug the three plastic connectors on the right side of the PCB board.
Remove the PCB board after all of the plastic connectors are disconnected.
You can now set it aside.
Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
Remove the two 15.5mm bottom silver screws with a Phillips #1 screwdriver.
Remove the PCB board mount and remove the clear plastic piece underneath.
Set them aside until you reassemble the wheel.
10 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Hi - help please. I disassembled my G27 and a 2 inch long semicircular metal clip fell out during the process. I don’t know what it is or where it came from.
