Zum Hauptinhalt wechseln
Disassembling Macintosh IIsi Floppy Drive
Was du brauchst
  1. Disassembling Macintosh IIsi Floppy Drive, Top Case: Schritt 1, Bild 1 von 2 Disassembling Macintosh IIsi Floppy Drive, Top Case: Schritt 1, Bild 2 von 2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Disassembling Macintosh IIsi Floppy Drive: Schritt 2, Bild 1 von 3 Disassembling Macintosh IIsi Floppy Drive: Schritt 2, Bild 2 von 3 Disassembling Macintosh IIsi Floppy Drive: Schritt 2, Bild 3 von 3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: Schritt 3, Bild 1 von 3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: Schritt 3, Bild 2 von 3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: Schritt 3, Bild 3 von 3
    • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
    • Push these two tabs out, and lift the drive up.
  4. Disassembling Macintosh IIsi Floppy Drive: Schritt 4, Bild 1 von 3 Disassembling Macintosh IIsi Floppy Drive: Schritt 4, Bild 2 von 3 Disassembling Macintosh IIsi Floppy Drive: Schritt 4, Bild 3 von 3
    • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
    • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
    • This drive was manufactured by Sony in 1990.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Chris Green
37.026 Reputation
49 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
321 Mitglieder
1.468 Anleitungen geschrieben
Ein Kommentar
Hi there, I have IIsi Mac but the driver couldn’t read all the floppy dsks!
note: it was stored for more than 7 years.
Q. How can I clean it and what is the suitable cleaning items you recommend?
thanks.
Abdulaziz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 2,777
