Zum Hauptinhalt wechseln
Disassembling Marshall MS-2 Micro Amp Case Disassembly
Was du brauchst
  1. Disassembling Marshall MS-2 Micro Amp Case Disassembly, Disassembling Marshall MS-2 Micro Amp Case Disassembly: Schritt 1, Bild 1 von 1
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Disassembling Marshall MS-2 Micro Amp Case Disassembly: Schritt 2, Bild 1 von 3 Disassembling Marshall MS-2 Micro Amp Case Disassembly: Schritt 2, Bild 2 von 3 Disassembling Marshall MS-2 Micro Amp Case Disassembly: Schritt 2, Bild 3 von 3
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Disassembling Marshall MS-2 Micro Amp Case Disassembly: Schritt 3, Bild 1 von 2 Disassembling Marshall MS-2 Micro Amp Case Disassembly: Schritt 3, Bild 2 von 2
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Disassembling Marshall MS-2 Micro Amp Case Disassembly: Schritt 4, Bild 1 von 1
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
MacKinley
811 Reputation
5 Anleitungen geschrieben
University of Maryland, Team 1-1, Shastany Fall 2013 Mitglied von University of Maryland, Team 1-1, Shastany Fall 2013
UMD-SHASTANY-F13S1G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 2,083
