Zum Hauptinhalt wechseln
Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis
Was du brauchst
  1. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: Schritt 1, Bild 1 von 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: Schritt 1, Bild 2 von 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: Schritt 1, Bild 3 von 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: Schritt 2, Bild 1 von 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: Schritt 2, Bild 2 von 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: Schritt 2, Bild 3 von 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: Schritt 3, Bild 1 von 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: Schritt 3, Bild 2 von 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: Schritt 3, Bild 3 von 3
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: Schritt 4, Bild 1 von 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: Schritt 4, Bild 2 von 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: Schritt 4, Bild 3 von 3
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: Schritt 5, Bild 1 von 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: Schritt 5, Bild 2 von 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: Schritt 5, Bild 3 von 3
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
Abschluss
Cal Poly, Team 6-9, Regan Fall 2011 Mitglied von Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 1,946
