Was du brauchst
Open the green case part by yours fingernail from left side to the right side with the usb socket
Be care of your labels
If you want to repair the SIM card slot legs, be sure no short circuits in 6 legs.
To release the PCB for cleaning the Display the the touch screen, remove 2 PARTS by fingernail.
1. Touchscreen adapter
2. Sticker between the touchscreen PCB & mobile PCB
Remove the mobile PCB much careful form top right. Be care the touchscreen circuits.
You can use a cloth, USB vacuum cleaner (be careful of the components in the green case), and adhesive tape to remove all the dust.
That finger pin is left by the Motorola Support Center in Hong Kong!!
You can also clean the camera lens on PCB
Remember to put all parts back and insert the touchscreen plugs slightly.
Put the green case back, make sure all locks is conneted
You can test the mobile before screw.
After insert the memory card, SIM card and battery, switch on the phone
Test call in and call out, also check the speaker
Open the map Apps to test Wifi and GPS
Bluetooth file transfer
Camera test and save in sd card
Check the sd card files
Try to connect with PC
If all works, remove the SIM card and battery.
Recheck the label is it on the top of the green case
Screws up all 6 screws
Put back all battery and SIM card
Close the back case and lock it
Close the USB cover
Done
If you want to explore what inside of the battery with PCB. Here is the step to follow.
Remove the label
Remove the black rubber
Tear the battery by hand (Be patient to repeat it many time) ***do not use any metal tools to cut it out!!
Also you can tear PCB by hand
Remove the black rubber Tear the battery by hand (Be patient to repeat it many time)
2 weitere Nutzer:innen haben diese Anleitung absolviert.
