Zum Hauptinhalt wechseln
Motorola V180 Connector Ribbon Replacement
Was du brauchst
  1. Motorola V180 Connector Ribbon Replacement, Connector Ribbon: Schritt 1, Bild 1 von 1
    • Gently tug on the upper edge of the faceplate, and it will easily detach.
  2. Motorola V180 Connector Ribbon Replacement: Schritt 2, Bild 1 von 1
    • Remove the four screws securing the front cover.
  3. Motorola V180 Connector Ribbon Replacement: Schritt 3, Bild 1 von 1
    • Gently glide the metallic silver cover outward.
    • This piece is wedged in tight. Try to slide out one hook at a time, instead of both simultaneously.
  4. Motorola V180 Connector Ribbon Replacement: Schritt 4, Bild 1 von 1
    • Insert a pair of tweezers between the silver and black sections of the cover.
    • The silver section should now easily snap away.
  5. Motorola V180 Connector Ribbon Replacement: Schritt 5, Bild 1 von 1
    • The black rubber component can now easily be taken off.
  6. Motorola V180 Connector Ribbon Replacement: Schritt 6, Bild 1 von 1
    • Use a soldering iron to detach the connector ribbon from the phone.
Abschluss
Tyler Knisley
1 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 6-16, Maness Spring 2010 Mitglied von Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 2,613
