Zum Hauptinhalt wechseln
Disassembling Motorola i850 LCD Board
Was du brauchst
  1. Disassembling Motorola i850 LCD Board, LCD Board: Schritt 1, Bild 1 von 1
    • Open the flip cover of the phone with the LCD screen facing towards you.
  2. Disassembling Motorola i850 LCD Board: Schritt 2, Bild 1 von 2 Disassembling Motorola i850 LCD Board: Schritt 2, Bild 2 von 2
    • Use a Razor Blade to remove the screw covers.
    • Razor Blade is very sharp. Use caution.
  3. Disassembling Motorola i850 LCD Board: Schritt 3, Bild 1 von 1
    • Unscrew the screws using a Phillips #00 Screwdriver.
  4. Disassembling Motorola i850 LCD Board: Schritt 4, Bild 1 von 1
    • Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
  5. Disassembling Motorola i850 LCD Board: Schritt 5, Bild 1 von 1
    • Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
  6. Disassembling Motorola i850 LCD Board: Schritt 6, Bild 1 von 1
    • Partially close the flip cover of the phone in order to take off the outer case.
  7. Disassembling Motorola i850 LCD Board: Schritt 7, Bild 1 von 1
    • Completely remove the outer casing from the phone.
  8. Disassembling Motorola i850 LCD Board: Schritt 8, Bild 1 von 2 Disassembling Motorola i850 LCD Board: Schritt 8, Bild 2 von 2
    • Place your thumb underneath the protective metal covering to remove it from the phone.
  9. Disassembling Motorola i850 LCD Board: Schritt 9, Bild 1 von 1
    • Gently detach the black microchip from the phone with a Tweezer.
  10. Disassembling Motorola i850 LCD Board: Schritt 10, Bild 1 von 1
    • Prop out the LCD board from the phone using your fingertips.
  11. Disassembling Motorola i850 LCD Board: Schritt 11, Bild 1 von 2 Disassembling Motorola i850 LCD Board: Schritt 11, Bild 2 von 2
    • Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
Abschluss
Andrew Aw
1 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 34-56, Forte Spring 2010 Mitglied von Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 2,407
