Zum Hauptinhalt wechseln
Disassembling Motorola i90c Internal Backplate
Was du brauchst
  1. Disassembling Motorola i90c Internal Backplate, Battery: Schritt 1, Bild 1 von 3 Disassembling Motorola i90c Internal Backplate, Battery: Schritt 1, Bild 2 von 3 Disassembling Motorola i90c Internal Backplate, Battery: Schritt 1, Bild 3 von 3
    • Slide the notch downward while pulling the back cover off to remove it.
  2. Disassembling Motorola i90c Internal Backplate: Schritt 2, Bild 1 von 3 Disassembling Motorola i90c Internal Backplate: Schritt 2, Bild 2 von 3 Disassembling Motorola i90c Internal Backplate: Schritt 2, Bild 3 von 3
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
  3. Disassembling Motorola i90c Internal Backplate, Antenna: Schritt 3, Bild 1 von 2 Disassembling Motorola i90c Internal Backplate, Antenna: Schritt 3, Bild 2 von 2
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
  4. Disassembling Motorola i90c Internal Backplate, Disassembling Motorola i90c Internal Backplate: Schritt 4, Bild 1 von 3 Disassembling Motorola i90c Internal Backplate, Disassembling Motorola i90c Internal Backplate: Schritt 4, Bild 2 von 3 Disassembling Motorola i90c Internal Backplate, Disassembling Motorola i90c Internal Backplate: Schritt 4, Bild 3 von 3
    • Unscrew the 3 screws shown.
    • Lift up the right part of the Nextel logo and unscrew the screw underneath.
  5. Disassembling Motorola i90c Internal Backplate: Schritt 5, Bild 1 von 2 Disassembling Motorola i90c Internal Backplate: Schritt 5, Bild 2 von 2
    • DO NOT force the cover off as it could damage the ribbon cable!
    • Gently lift the back cover off.
  6. Disassembling Motorola i90c Internal Backplate: Schritt 6, Bild 1 von 3 Disassembling Motorola i90c Internal Backplate: Schritt 6, Bild 2 von 3 Disassembling Motorola i90c Internal Backplate: Schritt 6, Bild 3 von 3
    • Carefully pry off the connection between the headphone jack and logic board.
Abschluss
Cal Poly, Team 29-61, Johann Spring 2010 Mitglied von Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,300
