Zum Hauptinhalt wechseln
Disassembling Motorola i90c Logic Board
Was du brauchst
  1. Disassembling Motorola i90c Logic Board, Battery: Schritt 1, Bild 1 von 3 Disassembling Motorola i90c Logic Board, Battery: Schritt 1, Bild 2 von 3 Disassembling Motorola i90c Logic Board, Battery: Schritt 1, Bild 3 von 3
    • Slide the notch downward while pulling the back cover off to remove it.
  2. Disassembling Motorola i90c Logic Board: Schritt 2, Bild 1 von 3 Disassembling Motorola i90c Logic Board: Schritt 2, Bild 2 von 3 Disassembling Motorola i90c Logic Board: Schritt 2, Bild 3 von 3
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
  3. Disassembling Motorola i90c Logic Board, Antenna: Schritt 3, Bild 1 von 2 Disassembling Motorola i90c Logic Board, Antenna: Schritt 3, Bild 2 von 2
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
  4. Disassembling Motorola i90c Logic Board, Midframe: Schritt 4, Bild 1 von 3 Disassembling Motorola i90c Logic Board, Midframe: Schritt 4, Bild 2 von 3 Disassembling Motorola i90c Logic Board, Midframe: Schritt 4, Bild 3 von 3
    • Unscrew the 3 screws shown.
    • Lift the right part of the Nextel logo
    • Remove the screw underneath.
  5. Disassembling Motorola i90c Logic Board: Schritt 5, Bild 1 von 2 Disassembling Motorola i90c Logic Board: Schritt 5, Bild 2 von 2
    • Forcing the cover off could damage the ribbon cable, so be careful when doing so.
    • Gently lift the back cover off.
  6. Disassembling Motorola i90c Logic Board: Schritt 6, Bild 1 von 3 Disassembling Motorola i90c Logic Board: Schritt 6, Bild 2 von 3 Disassembling Motorola i90c Logic Board: Schritt 6, Bild 3 von 3
    • Find the connection between the headphone jack and logic board.
    • Begin separating the two pieces, slowly and carefully.
  7. Disassembling Motorola i90c Logic Board, Logic Board: Schritt 7, Bild 1 von 2 Disassembling Motorola i90c Logic Board, Logic Board: Schritt 7, Bild 2 von 2
    • Lift the first logic board off of the rest of the device.
  8. Disassembling Motorola i90c Logic Board: Schritt 8, Bild 1 von 1
    • Gently lift the second logic board from the rest of the device.
    • DO NOT force the board straight off as it could damage the ribbon cable!
  9. Disassembling Motorola i90c Logic Board: Schritt 9, Bild 1 von 2 Disassembling Motorola i90c Logic Board: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Using tweezers, carefully pull off the connector shown.
Abschluss
Cal Poly, Team 29-61, Johann Spring 2010 Mitglied von Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 1,052
