Einleitung
Removing the stand from the rest of the monitor allows you to access and replace parts inside the display assembly.
Before beginning this guide, prepare a clean, flat surface to use as a workstation. Avoid working over carpeting, as small screws are used and, if dropped, may be lost in the carpet.
Was du brauchst
Firmly remove the back panel of the stand by pulling it up and away from the monitor.
Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
