Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
You will learn how to remove the front panel of the Nerf gun. The front panel of the Furyfire is the piece that closes onto the other half of the gun to enclose the components and hold them in place. Knowing how to remove the front panel is required for you to be able to perform any other repairs on the Furyfire.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. After the screws have been removed, gently lift the panel from the gun and set it aside.
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
Abschluss
Michael Cabossart
1 Reputation
1 Anleitung geschrieben
USF Tampa, Team 11-2, Blackwell Fall 2014 Mitglied von USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 3
Letzten 7 Tage: 3
Letzten 30 Tage: 10
Insgesamt: 597
