Zum Hauptinhalt wechseln
Disassembling Nokia 1110i (RH-93) made in Hongrie
Was du brauchst
  1. Disassembling Nokia 1110i (RH-93) made in Hongrie, Disassembling Nokia 1110i (RH-93) made in Hongrie: Schritt 1, Bild 1 von 3 Disassembling Nokia 1110i (RH-93) made in Hongrie, Disassembling Nokia 1110i (RH-93) made in Hongrie: Schritt 1, Bild 2 von 3 Disassembling Nokia 1110i (RH-93) made in Hongrie, Disassembling Nokia 1110i (RH-93) made in Hongrie: Schritt 1, Bild 3 von 3
    • Switch off the device to avoid shocks while disassembling.
    • Turn the device face down and press on the small button at the bottom . Slide the back case down.
    • To remove the battery, use your finger to insert it in the groove and pull the battery out.
  2. Disassembling Nokia 1110i (RH-93) made in Hongrie: Schritt 2, Bild 1 von 3 Disassembling Nokia 1110i (RH-93) made in Hongrie: Schritt 2, Bild 2 von 3 Disassembling Nokia 1110i (RH-93) made in Hongrie: Schritt 2, Bild 3 von 3
    • To remove the protective cover, use the tool shown and press the grey button at the left bottom.
    • The front cover ejects as shown. Remove it carefully to avoid damage.
    • The keypad case can be removed easily. Pull it up off the device.
    • Use a T6 Torx screwdriver to remove the screws.
  3. Disassembling Nokia 1110i (RH-93) made in Hongrie: Schritt 3, Bild 1 von 3 Disassembling Nokia 1110i (RH-93) made in Hongrie: Schritt 3, Bild 2 von 3 Disassembling Nokia 1110i (RH-93) made in Hongrie: Schritt 3, Bild 3 von 3
    • Find this channel at the top of your device.
    • Use a pair of tweezers to remove it carefully without harming the surroundings.
    • Insert the spudger into the section to remove the module.
  4. Disassembling Nokia 1110i (RH-93) made in Hongrie: Schritt 4, Bild 1 von 2 Disassembling Nokia 1110i (RH-93) made in Hongrie: Schritt 4, Bild 2 von 2
    • Use the spudger to remove the module casing safely.
    • Your device is successfully disassembled.
Abschluss
13 weitere Nutzer:innen haben diese Anleitung absolviert.
JDU TV
3.063 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 3,600
