Zum Hauptinhalt wechseln
Disassembling Nokia 2366i Front Cover
Was du brauchst
  1. Disassembling Nokia 2366i Front Cover, Battery: Schritt 1, Bild 1 von 2 Disassembling Nokia 2366i Front Cover, Battery: Schritt 1, Bild 2 von 2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Front Cover: Schritt 2, Bild 1 von 1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Front Cover: Schritt 3, Bild 1 von 3 Disassembling Nokia 2366i Front Cover: Schritt 3, Bild 2 von 3 Disassembling Nokia 2366i Front Cover: Schritt 3, Bild 3 von 3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Front Cover, Front Cover: Schritt 4, Bild 1 von 1
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
  5. Disassembling Nokia 2366i Front Cover: Schritt 5, Bild 1 von 2 Disassembling Nokia 2366i Front Cover: Schritt 5, Bild 2 von 2
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
  6. Disassembling Nokia 2366i Front Cover: Schritt 6, Bild 1 von 2 Disassembling Nokia 2366i Front Cover: Schritt 6, Bild 2 von 2
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Kristen
175 Reputation
1 Anleitung geschrieben
Cal Poly, Team 1-14, Amido Winter 2011 Mitglied von Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 1,188
