Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide show you how to access the phone's microphone, the component that receives sound when making a call.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Make sure your phone is turned off.
    • Make sure your phone is turned off.
  2. Press the button on the back of the phone and slide the back panel off.
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Note the small metal frame that  hold the SIM card into place.
    • Note the small metal frame that hold the SIM card into place.
    • Gently pull back the tab and lift open the frame.
  4. Retrieve your SIM card.
    • Retrieve your SIM card.
  5. Press the black tabs to release the front cover from the phone.
    • Press the black tabs to release the front cover from the phone.
  6. Remove the front cover from the phone.
    • Remove the front cover from the phone.
    • Set the front cover, as indicated, aside.
  7. Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
    • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
  8. Remove the screen assembly from the phone base.
    • Remove the screen assembly from the phone base.
    • Set the screen assembly aside.
  9. Note the location of the microphone.
    • Note the location of the microphone.
  10. Use tweezers to remove the microphone from the phone's base.
    • Use tweezers to remove the microphone from the phone's base.
  11. The microphone is now removed.
    • The microphone is now removed.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Sterling Fuentes
61 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 29-64, Johann Spring 2010 Mitglied von Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 1,991
