Einleitung
This guide shows you how to access the speaker of your phone, the component which produces sound.
Was du brauchst
Press the button on the back of the phone and slide the back panel off.
Remove the battery by pulling it from the phone.
Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
Carefully lift the keypad portion of the screen assembly from the circuit board.
Separate the screen from the circuit board.
Reconnect the ports during reassembly or the screen will not function properly.
You can now access the speaker.
Note the tab on the end of the speaker. It must be placed in correctly in order to reinstall the speaker.
