Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will show you how to remove the vibrator from the Nokia 3560.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Press down on the release latch on the bottom of the cover. Once the latch is released, lift the cover from the phone.
    • Press down on the release latch on the bottom of the cover.
    • Once the latch is released, lift the cover from the phone.
  2. Lift the front case off of the phone body.
    • Lift the front case off of the phone body.
  3. Lift the keypad off of the phone. Lift the keypad off of the phone.
    • Lift the keypad off of the phone.
  4. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  5. The screen is held to the body by six screws.
    • The screen is held to the body by six screws.
  6. Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
    • Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
  7. Insert a flat screwdriver between the black body and plastic layer. Insert a flat screwdriver between the black body and plastic layer.
    • Insert a flat screwdriver between the black body and plastic layer.
  8. Pry the layers apart. The LCD and plastic layer will lift out as one piece.
    • Pry the layers apart. The LCD and plastic layer will lift out as one piece.
  9. With the screws removed, the logic board can then be lifted out of the body by hand.
    • With the screws removed, the logic board can then be lifted out of the body by hand.
  10. The orange piece is the vibrator. It is not fastened by any means.
    • The orange piece is the vibrator.
    • It is not fastened by any means.
    • Remove with tweezers.
Abschluss
Sam Ryan
1 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 30-39, Garner Spring 2010 Mitglied von Cal Poly, Team 30-39, Garner Spring 2010
CPSU-GARNER-S10S30G39
5 Mitglieder
16 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 1,146
