Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide is a step by step process to remove the inner back cover of the phone. It is a preliminary step, to gain access to the inside elements of the phone.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn off the phone.
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Remove the back battery cover. Apply pressure on the cover while simultaneously sliding the cover downward. Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Insert the iPod opening tool between the base of the phone and the phone battery. Position the phone so that the battery won't fall out of the phone. The battery lifts out of the phone fast and easily.
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
  4. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  5. Turn the phone so that the back of the phone is facing forward.
    • Turn the phone so that the back of the phone is facing forward.
    • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
    • In this picture, the upper cover has already been removed.
  6. Place the iPod opening tool under the tabs near the top of the phone. Slide the iPod Opening Tool upwards.
    • Place the iPod opening tool under the tabs near the top of the phone.
    • Slide the iPod Opening Tool upwards.
    • This will pop the tabs and release the upper part of the phone.
    • Repeat for the left and the right sides.
  7. Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture). Lift the iPod opening tool to pop open the clips.
    • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
    • Lift the iPod opening tool to pop open the clips.
    • This will release the upper back cover of the phone.
  8. Push upward on the top back cover using two thumbs. This will remove the top back cover from the phone. This will remove the top back cover from the phone.
    • Push upward on the top back cover using two thumbs.
    • This will remove the top back cover from the phone.
Abschluss
Andrea
70 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 26-30, Regan Spring 2010 Mitglied von Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Mitglieder
17 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 2,098
