Zum Hauptinhalt wechseln
Disassembling Nokia 6086 Upper Back Cover
Was du brauchst
  1. Disassembling Nokia 6086 Upper Back Cover, Battery: Schritt 1, Bild 1 von 1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 6086 Upper Back Cover: Schritt 2, Bild 1 von 3 Disassembling Nokia 6086 Upper Back Cover: Schritt 2, Bild 2 von 3 Disassembling Nokia 6086 Upper Back Cover: Schritt 2, Bild 3 von 3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Disassembling Nokia 6086 Upper Back Cover: Schritt 3, Bild 1 von 3 Disassembling Nokia 6086 Upper Back Cover: Schritt 3, Bild 2 von 3 Disassembling Nokia 6086 Upper Back Cover: Schritt 3, Bild 3 von 3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
  4. Disassembling Nokia 6086 Upper Back Cover, Upper Back Cover: Schritt 4, Bild 1 von 1
    • Turn the phone so that the back of the phone is facing forward.
    • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
    • In this picture, the upper cover has already been removed.
  5. Disassembling Nokia 6086 Upper Back Cover: Schritt 5, Bild 1 von 2 Disassembling Nokia 6086 Upper Back Cover: Schritt 5, Bild 2 von 2
    • Place the iPod opening tool under the tabs near the top of the phone.
    • Slide the iPod Opening Tool upwards.
    • This will pop the tabs and release the upper part of the phone.
    • Repeat for the left and the right sides.
  6. Disassembling Nokia 6086 Upper Back Cover: Schritt 6, Bild 1 von 2 Disassembling Nokia 6086 Upper Back Cover: Schritt 6, Bild 2 von 2
    • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
    • Lift the iPod opening tool to pop open the clips.
    • This will release the upper back cover of the phone.
  7. Disassembling Nokia 6086 Upper Back Cover: Schritt 7, Bild 1 von 3 Disassembling Nokia 6086 Upper Back Cover: Schritt 7, Bild 2 von 3 Disassembling Nokia 6086 Upper Back Cover: Schritt 7, Bild 3 von 3
    • Push upward on the top back cover using two thumbs.
    • This will remove the top back cover from the phone.
Abschluss
Andrea
70 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 26-30, Regan Spring 2010 Mitglied von Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 14
Insgesamt: 2,213
