Einleitung
This guide helps you remove the display from the phone.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone. Lift the battery case off of the phone.
    • Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone. The battery should lift out with minimal resistance. The battery should lift out with minimal resistance.
    • Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone.
    • The battery should lift out with minimal resistance.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Locate the notch on the bottom right corner of the phone. Beginning at this point, slide the head of the screwdriver between the front casing and the rest of the phone. Continue to slide the screwdriver towards the top edge of the phone.
    • Locate the notch on the bottom right corner of the phone.
    • Beginning at this point, slide the head of the screwdriver between the front casing and the rest of the phone.
    • Continue to slide the screwdriver towards the top edge of the phone.
    • The front casing should eventually pop off.
  5. Locate the four screws on the upper half of the phone as indicated in the photo. Using the screwdriver indicated, unscrew each of these four fasteners. The LCD screen can be easily taken off once these screws are removed.
    • Locate the four screws on the upper half of the phone as indicated in the photo.
    • Using the screwdriver indicated, unscrew each of these four fasteners.
    • The LCD screen can be easily taken off once these screws are removed.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Erik Lindahl
48 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 10-46, Garner Spring 2010 Mitglied von Cal Poly, Team 10-46, Garner Spring 2010
CPSU-GARNER-S10S10G46
4 Mitglieder
10 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,461
