Einleitung
This guides you through removing the keypad.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone. Lift the battery case off of the phone.
    • Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone. The battery should lift out with minimal resistance. The battery should lift out with minimal resistance.
    • Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone.
    • The battery should lift out with minimal resistance.
  3. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  4. Locate the notch on the bottom right corner of the phone. Beginning at this point, slide the head of the screwdriver between the front casing and the rest of the phone. Continue to slide the screwdriver towards the top edge of the phone.
    • Locate the notch on the bottom right corner of the phone.
    • Beginning at this point, slide the head of the screwdriver between the front casing and the rest of the phone.
    • Continue to slide the screwdriver towards the top edge of the phone.
    • The front casing should eventually pop off.
  5. With the front casing removed, the keypad can easily be pulled off the back of the front casing.
    • With the front casing removed, the keypad can easily be pulled off the back of the front casing.
    • In all probability, it will already have fallen out and no removal is required.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Erik Lindahl
48 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 10-46, Garner Spring 2010 Mitglied von Cal Poly, Team 10-46, Garner Spring 2010
CPSU-GARNER-S10S10G46
4 Mitglieder
10 Anleitungen geschrieben
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 874
