Zum Hauptinhalt wechseln
Disassembling Olympus Stylus 725 SW Battery
  1. Disassembling Olympus Stylus 725 SW Battery, Disassembling Olympus Stylus 725 SW Battery: Schritt 1, Bild 1 von 2 Disassembling Olympus Stylus 725 SW Battery, Disassembling Olympus Stylus 725 SW Battery: Schritt 1, Bild 2 von 2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
Abschluss
Follow these instructions in reverse order to reassemble your device.
Bobby Hodges
49 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 33-71, Johann Spring 2010 Mitglied von Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 34
Insgesamt: 3,330
