Zum Hauptinhalt wechseln
Einleitung
Separating the logic board from the face plate.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
    • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  2. Remove the top screw on the back panel. Remove the top screw on the back panel.
    • Remove the top screw on the back panel.
  3. Slide off the case to expose the internal components of the receiver. Slide off the case to expose the internal components of the receiver.
    • Slide off the case to expose the internal components of the receiver.
  4. Laptop-Akkus
    Wenig Aufwand, große Wirkung.
    Jetzt kaufen
    Laptop-Akkus
    Jetzt kaufen
  5. Unscrew the three screws on top of the face plate. Unscrew the three screws on top of the face plate. Unscrew the three screws on top of the face plate.
    • Unscrew the three screws on top of the face plate.
  6. Unscrew the one screw on the bottom of the front panel. Unscrew the one screw on the bottom of the front panel.
    • Unscrew the one screw on the bottom of the front panel.
  7. Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force. Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force. Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
    • Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
  8. On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws. On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws. On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws.
    • On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws.
  9. You will see the same snaps along the top of the logic board. Press the heads of the snaps down and pull the logic board out and up. You will see the same snaps along the top of the logic board. Press the heads of the snaps down and pull the logic board out and up.
    • You will see the same snaps along the top of the logic board. Press the heads of the snaps down and pull the logic board out and up.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Ryan
90 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 27-92, Amido Spring 2010 Mitglied von Cal Poly, Team 27-92, Amido Spring 2010
CPSU-AMIDO-S10S27G92
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 2,227
